Comanche Joe Posted September 29, 2006 Share Posted September 29, 2006 New to the board all.... Love the site, and maybe someone can answer this questions for me... Will post pics soon 1987 Comanche 4x4 Longbed 4.0 (yes with RMS leaking) Auto Not sure of the gearing some rust, not too bad... 139K miles Link to comment Share on other sites More sharing options...
GirsMJ86 Posted September 29, 2006 Share Posted September 29, 2006 yes you can use 31s. it will rub if you turn too sharp but there is an easy fix for that. let me see if i can find the previous posts about this for ya. and have you had your rear main looked at? my 86 did that and it had the stupid seal that required like 17hrs of labor and was going to cost me over 1k to have it fixed. yours shouldnt be that much though since that was only a problem for the 86s. Alex Link to comment Share on other sites More sharing options...
GirsMJ86 Posted September 29, 2006 Share Posted September 29, 2006 here are some previous threads on this. you might want to ask pete if he still has that photo becuz IIRC it was a pretty good one to show what they look like. http://www.comancheclub.com/forums/view ... t=31s+lift http://www.comancheclub.com/forums/view ... t=31s+lift Alex Link to comment Share on other sites More sharing options...
Hot Rod Jeep Posted September 29, 2006 Share Posted September 29, 2006 Welcome aboard! If you're not scared of cutting the fenders have at it. I cleared 32's that way. 8) Link to comment Share on other sites More sharing options...
Comanche Joe Posted September 29, 2006 Author Share Posted September 29, 2006 what about wheels off a 99 wrangler? i know they will bolt up, but is offest a problem?? thanks Link to comment Share on other sites More sharing options...
possum Posted September 29, 2006 Share Posted September 29, 2006 Offset shouldn't be a problem. I ran a set of Primax aluminum wheels that I got off'n a 94 YJ Link to comment Share on other sites More sharing options...
87manche Posted September 29, 2006 Share Posted September 29, 2006 I ran stock wheels and suspension with 31x10.5's for a few months. observatons: They rub on the lower control arms at full steering lock, and the other side will rub on the steering skid if you have one. Some solutions: http://stu-offroad.com/steering/stop/steerstop-1.htm Adjust the steering stop Get grand cherokee control arms. Get wheels with less backspacing. The other observations: My 10.5's rub on the frame rail out back when I really work out the suspension. Your auto should have 3.55 gears, so it won't be horrible with 31's. Any larger and I would plan on regearing to get gas mileage and crawl ratio back. Link to comment Share on other sites More sharing options...
