DirtyComanche Posted September 27, 2006 Share Posted September 27, 2006 I have No A/C, no mech fan, and I'm tired of blowing alternators... Thought I saw a thread to do this before, but I'm not sure. So, if this is stock: Image Not Found I'd like to go to something like this: Image Not Found Or Image Not Found I'm not sure if I should keep the idler or not. Alternativly, I wanted to use the YJ V-belt setup. I have a v-belt PS pump and Alt already. However, I'd need some new pullies and a water pump... Thoughts? Link to comment Share on other sites More sharing options...
87manche Posted September 27, 2006 Share Posted September 27, 2006 I like the first one, but I could see slippage at the crank as a problem since you're only engaging about %50 of the pulley. Link to comment Share on other sites More sharing options...
mjeff87 Posted September 27, 2006 Share Posted September 27, 2006 On #1, would you still be able to tension the belt via the P/S pump? Doesn't look like you'd be able to get much adjustment with the belt running over the top of the pulley vs. around the side. Jeff Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 27, 2006 Author Share Posted September 27, 2006 Should be able to. There's a similar mod where you ditch the idler. The only difference is with mine you ditch the mech. fan and alternator location too. Link to comment Share on other sites More sharing options...
