89comanchesleeper Posted January 22, 2010 Posted January 22, 2010 i have a 89 mj 5 speed. it doesnt have a tilt colum in it and i want to swap one in it. any one know if its pretty easy to do?
JeepcoMJ Posted January 22, 2010 Posted January 22, 2010 yes. if you get one from an automatic equipped jeep, you'll need to tie the ignition lockout part on the column up/remove it somehow so that the key will start it instead of being locked up. but, it's pretty easy
89comanchesleeper Posted January 22, 2010 Author Posted January 22, 2010 ok cool thanks man. :cheers:
Geonovast Posted January 22, 2010 Posted January 22, 2010 In case you didn't know, XJ columns are the same. Any column 84-94 should go in pretty easily.
