shifter knob thread size.
Mine was glued as well , but the thread on the shifter comes out , you can put that thing in whatever you want .
Glue it back on and re-locktite the thread .
Here is mine I used a real pool ball for like 20 bucks . Used the stock thread and nut .
^^^I had a cue ball as a shift knob on mine, just drilled a hole a bit smaller than the stud and screwed it on. The stud cut the threads into the innards of the 'ball.
Then the a**hole neighbor kids stole it one day......
Jeff
