jeepaholic Posted January 12, 2010 Posted January 12, 2010 I would like to see a write up of anyones if they have linked the rear of their MJ..pics are a big help too..thanks.
cracker Posted January 12, 2010 Posted January 12, 2010 I would like to see a write up of anyones if they have linked the rear of their MJ..pics are a big help too..thanks. Can you narrow down your specifics? You looking to use the stock tank? You buggied out with a fuel cell?
jeepaholic Posted January 12, 2010 Author Posted January 12, 2010 I was thinking of chopping right behind the cab and building from there..Yes i plan on using a fuel cell..This is what i have right now...Minus an exo-cage around the cab... [img][/img]
92xjcowboy Posted January 13, 2010 Posted January 13, 2010 If your planning on chopping behind the cab then there isnt a whole lot that a write up can do for you. Everybodies setup is going to be different and depend on their specific plans and ideas. You should just look around on different 4x4 sites and see what people have been doing and work with a calculator (or not) and build it.
cracker Posted January 13, 2010 Posted January 13, 2010 I would go to Pirate then and look in the CHEROKEE forum. You'll see a TON of builds like that where people have to integrate into the unibody.
