Twisty Posted September 22, 2006 Share Posted September 22, 2006 can anyone post pics/give me an explanation of the location of the 8 bolts that hold on the bed to the frame? so far ive found 2, and I'm missing 6. I know that the gas tank and other things need to come off, but i think i have those covered. i know its a PITA, but the frame, and bed have rust that i need to take care of, and i can't with then bed on the truck. thanks for your help. :cheers: Link to comment Share on other sites More sharing options...
Xacto Posted September 22, 2006 Share Posted September 22, 2006 The 89 manual says there are 6 bolts as follows: -A nut and bolt at the rear of each sill member. Remove through sillmember hole. -Two nuts and bolts at each side ot the cargo box. Hope that helps. Link to comment Share on other sites More sharing options...
mike Posted September 22, 2006 Share Posted September 22, 2006 don't forget the 2 bolts on the X crossmember. the one that the spare tire hold against. you have to access them through the hole under each bolt. and don't forget the parking brake bracket, just undo the 3 bolts. also the wiring harness will have to come off, unplug it at the drivers side, it's a big fat connector. good luck, i removed my bed by myself using an engine lift, attached rope to the 4 corner brackets in bed and it lifted right off. Link to comment Share on other sites More sharing options...
Twisty Posted September 23, 2006 Author Share Posted September 23, 2006 ok, i found the 8, or i think i did. I'm going to go out again tomorrow and dump some more PB blaster on them. thanks for the help guys!! mike, I'm a little confused about the Xmember. Ill take another look tomorrow, and if i need further clarification ill post it up. :cheers: Link to comment Share on other sites More sharing options...
comancheman Posted September 23, 2006 Share Posted September 23, 2006 if u have rust problems i would definetly heat each bolt. i didnt and ended up snapping 6 out of 8 but i have serious rust issues. still wouldnt hurt though Link to comment Share on other sites More sharing options...
mike Posted September 23, 2006 Share Posted September 23, 2006 hey twisted, the X member is where the spare tire holds against. the frame is in the shape of a big X, i don't know if thats what the factory calls it but thats what it looks like. ;) Link to comment Share on other sites More sharing options...
Twisty Posted September 23, 2006 Author Share Posted September 23, 2006 ooook i got ya mike. i thought you were talkin about the TC crossmember...that was a little confusing for me. thanks for the clarification!! Link to comment Share on other sites More sharing options...
jbhill Posted September 25, 2006 Share Posted September 25, 2006 that would be called the spare tire carrier. theres 10 if you count the e-brake bracket. really i don't see the need for 2 bolts upfront and 6 in the rear. 4 on the frame rail at the rear and 2 in the X member. Link to comment Share on other sites More sharing options...
