Jakeman17 Posted December 24, 2009 Share Posted December 24, 2009 I was driving to my friends house and i went to push the clutch in(i was in 3rd) and the pedal had no pressure until about the floor. So When it is out of gear the pedal is normal. wHEN IN GEAR THE pedal is almost non existance. THere is no fluid on or by the fuse box... Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 24, 2009 Share Posted December 24, 2009 slave cylinder? man i think i know why that guy sold it lol Link to comment Share on other sites More sharing options...
Geonovast Posted December 24, 2009 Share Posted December 24, 2009 Did you at least check the fluid level? Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 24, 2009 Author Share Posted December 24, 2009 no i will but it was cold i was in shorts and a t-shirt Link to comment Share on other sites More sharing options...
Eagle Posted December 24, 2009 Share Posted December 24, 2009 There are only three possibilities -- the master cylinder, the slave cylinder, or the hose/line that connects the two. You have to check all three to determine which one is causing the problem. But ... This does not make any sense: So When it is out of gear the pedal is normal. wHEN IN GEAR THE pedal is almost non existance. The clutch does not know or care whether or not the transmission is in gear. The clutch pedal pushes a column of hydraulic fluid that presses against the clutch fingers to move the pressure plate away from the flywheel and clutch disk. Being in gear or not doesn't in any way affect that. Please try it again and pay more careful attention to what it's doing. More than likely, you were almost out of fluid and happened to catch the last few drops when you thought it felt normal. This may help: http://auto.howstuffworks.com/clutch1.htm Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 24, 2009 Author Share Posted December 24, 2009 The fluid is full. It did matter in or put of gear. In gear it went to floor. Out of gear I had to put effort to push it Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 24, 2009 Share Posted December 24, 2009 let's just throw the ax15 in it and get the 4x swap done a.s.a.p. so you don't even have to worry about it... Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 24, 2009 Author Share Posted December 24, 2009 Ok I like your thinking Pat Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 24, 2009 Author Share Posted December 24, 2009 when I push the brake and clutch at the same time there is a hissing nosie...... I just drove about 30 miles and fluid level is still the same I could smell brake fluid for about 2 mins then couldnt Link to comment Share on other sites More sharing options...
Automan2164 Posted December 24, 2009 Share Posted December 24, 2009 Maybe the master has an internal seal leak? Are you positive that there isn't fluid coming down the firewall? Rob L. Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 24, 2009 Author Share Posted December 24, 2009 Yes I just checked. Fluid levels are still the same as yesterday I was feeling around nothing was wet Link to comment Share on other sites More sharing options...
Automan2164 Posted December 24, 2009 Share Posted December 24, 2009 Well if you can hear that "sound" it could be fluid leaking past the piston in the master... Rob L. Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 24, 2009 Author Share Posted December 24, 2009 I know..... Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 24, 2009 Author Share Posted December 24, 2009 the MC is like $30 so i guess ill try that Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 26, 2009 Author Share Posted December 26, 2009 So i can change one MC which one Clutch or Brake? Link to comment Share on other sites More sharing options...
Automan2164 Posted December 26, 2009 Share Posted December 26, 2009 That english? Rob L. Link to comment Share on other sites More sharing options...
Eagle Posted December 26, 2009 Share Posted December 26, 2009 So i can change one MC which one Clutch or Brake? You are having a problem with the clutch. Why would you consider changing the brake master cylinder? I know you want to get your truck fixed, and I sympathize. But you're not thinking. You're just going to go out and throw a part at it, hoping you change the right part. If you don't, you'll just end up changing one unnecessary part after another, spend a lot of money, and maybe you'll eventually get it fixed. Slow down, take a deep breath, and figure out what's wrong before you start throwing parts at it. Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 26, 2009 Author Share Posted December 26, 2009 I understand that but I need to be able to drive it on Monday. The master cylinder(brake) need to be changed there is a nice hissing noise when I'm on the brakes and pedal slowly goes to the floor. I have to be able to drive it until theres a chance to get it completely fixed Link to comment Share on other sites More sharing options...
Automan2164 Posted December 26, 2009 Share Posted December 26, 2009 Wait, so has this whole problem been with your brakes, or with your clutch? I thought clutch? Rob L. Link to comment Share on other sites More sharing options...
Lenard Posted December 26, 2009 Share Posted December 26, 2009 Wait, so has this whole problem been with your brakes, or with your clutch? I thought clutch? Rob L. I'm confused to :huh???: :D Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 26, 2009 Author Share Posted December 26, 2009 its clutch nevermind Link to comment Share on other sites More sharing options...
Automan2164 Posted December 26, 2009 Share Posted December 26, 2009 Have you done the clutch master? Rob L. Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 26, 2009 Author Share Posted December 26, 2009 no Link to comment Share on other sites More sharing options...
Automan2164 Posted December 26, 2009 Share Posted December 26, 2009 So the clutch was the one dropping when you pressed it, but now the brake is doing it too? :huh???: :hmm: I am going nuts... Maybe I should just call you. Rob L. Link to comment Share on other sites More sharing options...
