Jakeman17 Posted December 9, 2009 Share Posted December 9, 2009 Someone said I could get different rear brake lines bc of my lift. What are there? And the rear height sensing vavle. Is there a certain one I should get bc of lift? Link to comment Share on other sites More sharing options...
89eliminator Posted December 9, 2009 Share Posted December 9, 2009 dodge dakota brake line(not sure what year) is what you need. i got this prop valve for mine... http://www.summitracing.com/parts/SUM-G3905/ Link to comment Share on other sites More sharing options...
Jakeman17 Posted December 9, 2009 Author Share Posted December 9, 2009 Thanks Wade I need drums-100 shoes-15 hardware kit-10 lines prop valve-40 Well mine lines are not leaking just torn so I'll get brakes for now then get prop valve and lines Link to comment Share on other sites More sharing options...
mjeff87 Posted December 9, 2009 Share Posted December 9, 2009 to install that Dakota line "correctly" you have to drill out and retap the bolt hole that is currently holding your stock line/junction block to the tube. The Dakota line is a bit different in that it utilizes that bolt also as the vent (it's a hollow bolt). I drilled out the small stock vent hole and tapped it to the Dakota bolt thread size/pitch while I was building the axle on a bench and the axleshafts were out, so I was able to catch all the metal shavings inside the tube when I did it. I also shortened it a bit so it cleared the axleshaft inside the tube. There are other methods to attach the junction block to the tube (zipties, band clamps, etc) if you don't want to bother doing all that, though. Jeff Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 10, 2009 Share Posted December 10, 2009 just use the old bolt and a washer on the dakota line. done, finished. also, I ALWAYS turn the dakota brake line to sit on the axle tube the way it was meant to...it has a little indent on the T section that allows it to sit flush. year is 93-95 Link to comment Share on other sites More sharing options...
