tmanhollister Posted December 8, 2009 Posted December 8, 2009 ive looked everywhere to see if someone is selling a poly tranny mount. i found some for manual trannys....but none for the autos...does anyone know where i can find one or if there is even one out there...the oem mount is only $40 but if you gotta fix it you might as well upgrade right...its a 89 4.0 auto 4x4 btw.
WBKrazy Posted December 8, 2009 Posted December 8, 2009 i've never seen one either, but if you find one let me know, i'd like one too.....
LoTGoD Posted December 8, 2009 Posted December 8, 2009 Will anything here work? http://www.4wd.com/search.aspx?SH=QT1Uc ... werID=1311
deziped Posted December 8, 2009 Posted December 8, 2009 Daystar 1-1/2" Transmission Mount in Black for 84-01 Jeep® Cherokee XJ All of Daystar's™ mounts are constructed of heavy duty steel that is fully welded and interlocked for extreme duty strength. Daystar™ uses its special blend of Polyurethane to isolate the mount from the engine and reduce the amount of power loss a traditional mount allows... more » Click here for details $52.99 #76058.831 The above is the sales pitch in Quadratec's on-line catalog listed under transmission stuff. A couple of mounts on that page are poly........
Geonovast Posted December 8, 2009 Posted December 8, 2009 I'm 99% sure the AW-4 and AX-15 use the same mount, so a poly mount for the AX-15 should work for you.
