87Warrior Posted November 24, 2009 Share Posted November 24, 2009 Received this e-mail from POR-15 and thought I should share with my fellow MJ'ers since rust is our enemy. Thanksgiving Free Shipping Offer Use code TDFSO when ordering online and have your order shipped to you FREE! This offer is valid Thanksgiving weekend (Thurs, Fri, Sat & Sun) only! Visit us online at http://www.por15.com/ Link to comment Share on other sites More sharing options...
jpnjim Posted November 26, 2009 Share Posted November 26, 2009 Figures I just ordered 4 quarts & some other stuff from them a couple weeks ago. :doh: Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted November 26, 2009 Share Posted November 26, 2009 is this a good price? Pint............ $29.95 Quart......... $44.95 Gallon........ $143.00 Link to comment Share on other sites More sharing options...
jpnjim Posted November 26, 2009 Share Posted November 26, 2009 is this a good price? Pint............ $29.95 Quart......... $44.95 Gallon........ $143.00 That's around what I paid ($40-something a quart), Getting a gallon's a bad idea, unless you're going to burn through the whole thing in a short time. It doesn't last long after you open it (best to seal with plastic wrap under the cover & refrigerate the unused portion), and is easily contaminated (I always scoop the paint out into another container to brush from, then seal original container). I only opened one of the 4 qts I bought so far, but the lid was friggen 'paint-welded' to the can. I never had this happen before (esp with a new can), but I had to destroy the container to open it. :fs1: As far as prices, I did find one place selling it online for ~$37 a quart, but figured they'd probably hit you on shipping (since every other place I found was $41-45 a quart). :dunno: edit: I actually got the 4-qt deal this time, and they knock like $20 off the total. Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted November 26, 2009 Share Posted November 26, 2009 Is a Quart more than what I’d need to thickly coat the interior of MJ's cab floor? And will Line-x/Rhino liner adhere it ok? Link to comment Share on other sites More sharing options...
87Warrior Posted November 26, 2009 Author Share Posted November 26, 2009 A quart would be more than enough to cover the floor pans. I used about 3/4 inch out of a pint to do my D44. Not sure if liner will stick or not. Link to comment Share on other sites More sharing options...
jpnjim Posted November 26, 2009 Share Posted November 26, 2009 A quart should do it. Find out what primer works best with the bedliner, when the 2nd coat of POR-15 is tacky to the touch, spray a dusting of the primer over the POR-15. Let that completely dry, then follow the instructions on the can of primer. (might say: "2nd coat before 4 hours, or after 48 hrs", or something like that) POR-15 also makes a tie-cote to use over POR-15, but I've had good luck doing the above. Link to comment Share on other sites More sharing options...
