landlubber Posted November 16, 2009 Share Posted November 16, 2009 Greetings fellow club members. I have been working on fixing my oil pan leak in what Limited time I have (sundays) but I had a day off from school (Vets day) so I got some work done. Got the pan pulled out - what a female dog. Anyways, I figured I'd clean it up a little. So I did. Didn't give much thought to the heat resistance of the paint applied - It is 200F. So the question: will paint with a 200F heat resistance be ok for the oil pan? please advise. Mind as well get it right while I have the tools, pan off, and the opportunity to. thanks -landlubber ps. after this oil leak, wipers and I'll pass inspection, and I'm 18 tomorrow. :cheers: Link to comment Share on other sites More sharing options...
Eagle Posted November 16, 2009 Share Posted November 16, 2009 Ideally, you should use engine paint. The coolant runs at over 200 degrees. I don't know what the oil gets up to, but I'm pretty sure it's quite a bit hotter than 200. Link to comment Share on other sites More sharing options...
landlubber Posted November 16, 2009 Author Share Posted November 16, 2009 I already got some engine paint thinking on doing it right, Just thought i'd ask first. Link to comment Share on other sites More sharing options...
terrawombat Posted November 16, 2009 Share Posted November 16, 2009 You'll want to put some higher temp paint on. I used paint intended for charcoal grills. It was pretty cheap and has a very high temperature rating. Picked it up at Home Depot and brushed it on - nice matte black finish and it has held up pretty well so far. Ideally, I would have liked to use some high temperature paint with resistance to rock chips, but now we're talking more $$ Link to comment Share on other sites More sharing options...
Randy in Maine Posted November 17, 2009 Share Posted November 17, 2009 I used "black velevet" since I had some laying around. http://www.por15.com/BLACK-VELVET/productinfo/BVG/ Getting the grease off it was the worst. Use the gasket from the dealer as opposed to the NAPA one if you do not want it to leak. That was over 5 years ago and it is still in great shape. Oil temps should run in the 180-220º range. Link to comment Share on other sites More sharing options...
landlubber Posted November 17, 2009 Author Share Posted November 17, 2009 I got the gasket from FelPro. I picked up some Dupli-color Engine enamel. Good to about 500 deg. semi-gloss black. Link to comment Share on other sites More sharing options...
