freakjeep93 Posted November 16, 2009 Share Posted November 16, 2009 i was thinkiing about an old xj we had as a donor and my dad says it had a 4 cyl carberated engine and I'm just wondering if the xj ever came with that? Link to comment Share on other sites More sharing options...
Pete M Posted November 16, 2009 Share Posted November 16, 2009 84-85 2.5Ls had the carb Link to comment Share on other sites More sharing options...
freakjeep93 Posted November 16, 2009 Author Share Posted November 16, 2009 okay antidisestablishmentarianism would an xj with that motor and an auto transmission have for gears? Link to comment Share on other sites More sharing options...
Pete M Posted November 16, 2009 Share Posted November 16, 2009 dunno for sure. The rules-of-thumb weren't as reliable for the early years. Link to comment Share on other sites More sharing options...
dunl Posted November 16, 2009 Share Posted November 16, 2009 DAMMMMM! Most likely 4.56's, you lucky SOB. :D Link to comment Share on other sites More sharing options...
Automan2164 Posted November 16, 2009 Share Posted November 16, 2009 Rumored that an auto 4 cyl has 4.56 gears stock. Rob L. Link to comment Share on other sites More sharing options...
Pete M Posted November 16, 2009 Share Posted November 16, 2009 I wouldn't bet much money on that. I'm guessing 3.31 or 3.73 (looked it up on car-part.com) Link to comment Share on other sites More sharing options...
dunl Posted November 16, 2009 Share Posted November 16, 2009 Jack her up and turn the wheels. ;) Link to comment Share on other sites More sharing options...
freakjeep93 Posted November 16, 2009 Author Share Posted November 16, 2009 i know whats goin in my jeep oh and it SOA too, only problem is that its has a bunch of holes in the cover so there hasnt been any oil in it for like 5 years. but it should still be fine. Jack her up and turn the wheels. ;) and the axel is already out and the breaks are seized Link to comment Share on other sites More sharing options...
dunl Posted November 16, 2009 Share Posted November 16, 2009 Pull the cover. lol Link to comment Share on other sites More sharing options...
Pete M Posted November 16, 2009 Share Posted November 16, 2009 doesn't matter if it's SOA. the XJ perches are in the wrong spot for an MJ. I'd be very leery about purchasing it. Link to comment Share on other sites More sharing options...
dunl Posted November 16, 2009 Share Posted November 16, 2009 Used to be his dad's, Pete. ;) No cost involved. Link to comment Share on other sites More sharing options...
freakjeep93 Posted November 16, 2009 Author Share Posted November 16, 2009 I'm gunna . does it say on the ring gear or do i count the teeth or sompthin doesn't matter if it's SOA. the XJ perches are in the wrong spot for an MJ. I'd be very leery about purchasing it. ive already got the axel and i was just gonna mover the perches over to the right spot. how far over do i move them ? Link to comment Share on other sites More sharing options...
Pete M Posted November 16, 2009 Share Posted November 16, 2009 Used to be his dad's, Pete. ;) No cost involved. No cost to buy does not necessarily mean no cost to get running. Link to comment Share on other sites More sharing options...
dunl Posted November 16, 2009 Share Posted November 16, 2009 That's true. :cheers: Link to comment Share on other sites More sharing options...
Automan2164 Posted November 16, 2009 Share Posted November 16, 2009 Its says the gear ratio in a set of numbers on the ring, or the shaft of the pinion. It will be the number of teeth on each... For example, the gearset I have been staring at lately is a 3.73 in my ZJ... On the ring gear, it has 41 11 next to each other, a little set off from the part number... 41 teeth on the ring, 11 on the pinion. Divide 41 by 11, and you get 3.727, which is rounded up to 3.73. Rob L. Link to comment Share on other sites More sharing options...
freakjeep93 Posted November 16, 2009 Author Share Posted November 16, 2009 Its says the gear ratio in a set of numbers on the ring, or the shaft of the pinion. It will be the number of teeth on each... For example, the gearset I have been staring at lately is a 3.73 in my ZJ... On the ring gear, it has 41 11 next to each other, a little set off from the part number... 41 teeth on the ring, 11 on the pinion. Divide 41 by 11, and you get 3.727, which is rounded up to 3.73. Rob L. okay thanks alot man Link to comment Share on other sites More sharing options...
Automan2164 Posted November 16, 2009 Share Posted November 16, 2009 Or, worst case, just count the teeth on both, and divide the ring by the pinion. Rob L. Link to comment Share on other sites More sharing options...
dunl Posted November 16, 2009 Share Posted November 16, 2009 Divide the ring gear teeth by the pinion teeth, if I remember correctly? For example....41 ring gear/ 10 pinion = 4.10's? Someone correct me if I am wrong here. :huh???: :dunce: Edit: The man in the black hat with the fastest draw wins. :D Link to comment Share on other sites More sharing options...
freakjeep93 Posted November 16, 2009 Author Share Posted November 16, 2009 alright ill do that tomorrow. does anyone know offhand the width id need to put the perches at ? for a mj Link to comment Share on other sites More sharing options...
Pete M Posted November 16, 2009 Share Posted November 16, 2009 I think it's 42" center to center. Link to comment Share on other sites More sharing options...
Automan2164 Posted November 16, 2009 Share Posted November 16, 2009 Just wheel the axle underneath the MJ, and test fit it... Nothing is ever set in stone with these things. Once you get it all set, burn the perches in. Rob L. Link to comment Share on other sites More sharing options...
Pete M Posted November 16, 2009 Share Posted November 16, 2009 You've got an MJ axle under the MJ right now, yes? Link to comment Share on other sites More sharing options...
dunl Posted November 16, 2009 Share Posted November 16, 2009 Measure the old one. Link to comment Share on other sites More sharing options...
freakjeep93 Posted November 16, 2009 Author Share Posted November 16, 2009 yea Link to comment Share on other sites More sharing options...
