You can't just bolt them to the unibody "frame" as the bolts will tear through the first time you use them. Factory brackets may be had from a junk yard Cherokee, I myself use "Custom 4x4" brackets, there are other ones out there, including some that were designed with input from some members on here.
Anything made for the front of a Cherokee works on the front of a Comanche.
That steel is quarter inch thick. By the time you buy it, cut it to shape, and make the bends needed for it to work -- it'll be cheaper (and better) to just buy the set from Custom 4x4
