brak Posted November 6, 2009 Share Posted November 6, 2009 i tried a search and found nothing. has anyone changed the shifter from a column mount to a floor mount? for an automatic of course. also if i do decide to keep the column mount, is there a way to fit a PRND321 indicator that is on column itself instead of in the cluster? i figured having it on the column itself will make it easier when i do a gauge swap. Link to comment Share on other sites More sharing options...
Eagle Posted November 6, 2009 Share Posted November 6, 2009 There's an aftermarket PRNDL that mounts directly on the column. Somebody here installed one and posted photos and a link to the company. Don't think it was Hornbrod. Maybe 87jeffmj? Link to comment Share on other sites More sharing options...
Geonovast Posted November 6, 2009 Share Posted November 6, 2009 viewtopic.php?f=9&t=14904 For the PRND321 You can grab a floor shift kit out of an XJ, and swap it into your truck. Then you can get a regular column and throw that in too. It should all directly swap over. Link to comment Share on other sites More sharing options...
