partsmj Posted September 14, 2006 Share Posted September 14, 2006 If you know someone at a dealer that still has a DRBII with the Jeep adapter, you can check the sensor and make sure it is adjusted properly. The setting is 13% at idle. Link to comment Share on other sites More sharing options...
comanchedude Posted September 15, 2006 Share Posted September 15, 2006 I think you know the problem The VIN is 1JTHR65T0HT053241 4 H Engine 2,5 litres, I-4, central injection you stated you have a 6cy in the truck now...4cy tach? Link to comment Share on other sites More sharing options...
GirsMJ86 Posted September 15, 2006 Share Posted September 15, 2006 I think you know the problem The VIN is 1JTHR65T0HT053241 4 H Engine 2,5 litres, I-4, central injection you stated you have a 6cy in the truck now...4cy tach? i was starting to wonder if anyone would notice that. now if that is the real problem or not it is hard to tell without being around the truck to see what else it might be i think. Alex Link to comment Share on other sites More sharing options...
Eagle Posted September 15, 2006 Share Posted September 15, 2006 I think you know the problem The VIN is 1JTHR65T0HT053241 4 H Engine 2,5 litres, I-4, central injection you stated you have a 6cy in the truck now...4cy tach? i was starting to wonder if anyone would notice that. now if that is the real problem or not it is hard to tell without being around the truck to see what else it might be i think. Alex Well, at least I read the symptoms correctly. So what if it was the engine that was swapped rather than the tach? By the way -- the '88 tach is adjustable. Take out the gauge cluster and look at the back of the tach. You should see a potentiometer. In rough terms, all the way to one side is the 4-cyl setting and all the way to the other side is for 6-cylinders. If you have access to a good idle tach or a professional scanner machine you can fine tune it, but just turning the pot to the opposite end of the range from where it is now will put you in the ball park. I don't know if your '87 tach is the later style, like the '88 and adjustable, or the early style (like the '86) and non-adjustable. You'll have to look at the back of it to see if it has a potentiometer. Link to comment Share on other sites More sharing options...
4play Posted September 16, 2006 Author Share Posted September 16, 2006 Next day off I guess I'll pull things apart and see whats there. I think you are on the right track about the tach. Thanks much. :D Link to comment Share on other sites More sharing options...
