fiatslug87 Posted September 10, 2006 Posted September 10, 2006 I'm trying to remove the fuse panel in my '88 MJ. I need to access the bulkhead connector to which the panel is attached because water leaks past it into the cab. I've loosened the two screws and the panel loosens, but I can't seem to remove it. Is there a locking tab(s) I don't see or another fastener? Thanks for the help.
jeepthing07 Posted September 11, 2006 Posted September 11, 2006 there is a bolt you have to remove on the engine compartment side right in the middle of the big block connector. its not visable its hidden up in there and it takes a 1/4" socket with a extension. :cheers:
fiatslug87 Posted September 11, 2006 Author Posted September 11, 2006 there is a bolt you have to remove on the engine compartment side right in the middle of the big block connector. its not visable its hidden up in there and it takes a 1/4" socket with a extension. :cheers: Thanks, that was it. Now why would they put a bolt right there where it can't be seen? Good ol' engineers.
Oizarod115 Posted September 11, 2006 Posted September 11, 2006 hindsight 20-20 type a thing probably :chillin:
