Hi All,
I spent about 2 hours trying to find the post in the forum and just could not come up with an answer.
I have a 87 MJ and just found some seats from a 97 Cherokee.
My truck had the beach seat in it and a slider swap looks like it would not work (i.e. two rail sliders per bucket seat).
What is a fella to do?
Any help or suggestions?
Thanks in advance,
Kevin
Hi Kevin I hope this post helps some,
viewtopic.php?f=2&t=14979
It much easier to swap older Cherokee buckets 2 door one are best as they will tilt forward. Your bench has 2 brackets on each side so there are enuf brackets under there. But it has been done putting 97+ buckets in.
The 97 seats are different. The whole bracket setup is different. U wouldnt beable to use them. Unless theres a writeup on that setup can't remember. The up to early 90s u can use your seat brackets.
I swapped '97 seats in recently. I had to cut and reweld the outboard rear mounts, also cut and angled the inside rear mounts. Then I cut off the downward tab on the front ones and used some square stock to make front pedestals. I mounted the front pedestals right behind the floor crossmember. Depending on how tall you are will depend on where you need to locate. If I get the chance sometime soon, I'll snag some pics.
-Gary
