Bansheemanche Posted October 15, 2009 Share Posted October 15, 2009 I was wondering where I can get a MAT sensor for my 88 manche with the 4.0 (renix)? I need one and can't see to find it through autoparts stores. Do I have to get this through the dealer or used? Link to comment Share on other sites More sharing options...
rworks Posted October 15, 2009 Share Posted October 15, 2009 Do you mean MAP sensor? I don't recall any MAT sensors. If you mean MAP, Rockauto has them. STANDARD MOTOR PRODUCTS Part # AS5 or AS5T Link to comment Share on other sites More sharing options...
Puritan21 Posted October 15, 2009 Share Posted October 15, 2009 Intake maniflod air sensor......I feel your pain. Finally figured out that this is my problem, but couldn't find one locally either. Here is a couple links to get one online. http://www.tomco-inc.com http://www.rigidsteel.com Rigidsteel is about 15 bucks cheaper shipped to the door, so that's who I'll probably order it from. Link to comment Share on other sites More sharing options...
mjeff87 Posted October 15, 2009 Share Posted October 15, 2009 be careful when removing the old one from the manifold......I swapped one on my old 2.5 and the old one snapped clean off at the threads, flush with the manifold. I ended up having to use a fluted extractor to turn the remnants of it out and then clean out the manifold before installing the new one :fs1: It's a brass fitting into an aluminum manifold (dissimilar metals), and the factory loctite didn't help the situation any, either..... Jeff Link to comment Share on other sites More sharing options...
Bansheemanche Posted October 15, 2009 Author Share Posted October 15, 2009 Thanks! Just what I needed, I got on rigid steel and ordered the 1987-90 2.5L & 4.0L XJ Cherokee, on intake manifold temperature sensor. Hopefully that is the right one as the description was off. Thanks again! Link to comment Share on other sites More sharing options...
Puritan21 Posted October 16, 2009 Share Posted October 16, 2009 No prob, ordered the same one today. It hase the same part number as the dealer, so it should be it !! :clapping: Link to comment Share on other sites More sharing options...
Bansheemanche Posted October 19, 2009 Author Share Posted October 19, 2009 You ordered one too? I never got any email conformation or anything? Is that site up and running? Link to comment Share on other sites More sharing options...
Puritan21 Posted October 21, 2009 Share Posted October 21, 2009 I never received an email either. I hope the sensor its on its way..... Link to comment Share on other sites More sharing options...
Puritan21 Posted December 3, 2009 Share Posted December 3, 2009 I gave up on Rigid-Steel.....from the ad in classifieds looks like they are going under. Ordered one from http://www.tomco-inc.com Hopefully I'll get this one. Link to comment Share on other sites More sharing options...
