Frost Plug Issue!
Ok, I've done a lot of searching on this issue. I picked up an '87 manche 2.5l 2x4 for $350. Obviously the truck is not mint! that's why I bought it. I had to replace the drive belt on site before I could even get it out of there. The thing leaks coolant... not just a little bit but A lot! the reservoir is full but the rad is empty and when I try to fill it, fluid spills out from around the bell housing. Every visible plug is still holding solid. Is there a plug that I can only get at by removing the tranny?
There's one in the back of the head above the bell, and yes, there is one in the back of the block. You have to pull the tranny and flywheel to access it.
Jeff
Thanks. I spotted the one in the back of the head above the bell and it looks solid. I figured I would have to pull the tranny and flywheel. I haven't found too much info on this particular issue. It must not be a very common. Seems how I'm already halfway there, is there anything else I should inspect/fix while I have it torn down?
R&R the clutch while you have it all apart if you want to.
Also, the rear main seal in a 2.5 is a one-piece deal (unlike the 2 pc one on a 4.0).....I'd suggest replacing it while you have the flywheel off. It only costs about $5 :D
Check the other welch plugs as well on the side of the block.
Jeff
edit: Don beat me to it..... :yes:
Don't forget the possibility of a blown headgasket. It is possible for it to blow out between the coolant valley and the end of the block, so it won't get into the cylinders or oil and affect how the motor runs.
If it ends up not being the freeze plug, at least head gaskets aren't that bad to do.
