mjstiltheydie Posted September 6, 2006 Share Posted September 6, 2006 Can an ax15 transmission from a 2wd truck be used in a 4x4? Link to comment Share on other sites More sharing options...
Oizarod115 Posted September 6, 2006 Share Posted September 6, 2006 from what i understand from previous discussion of the matter... no, the 2wd AX15s can't be turned into 4x4 without alot of troublesome (maybe even impossible) work. I'm sure someone else has a more definate answer though Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 6, 2006 Share Posted September 6, 2006 Well, you can. You'd need a 4wd AX-15 to donate parts though, or buy new parts (scary expensive). Then basically it's a complete rebuild. Most guys are afraid of trannies, for pretty good reasons. Get a 4wd AX-15. (Oh, as a curiosity, you could run a divorce tcase and use a 2wd tranny. But it would be WAY more work than it is worth) Link to comment Share on other sites More sharing options...
