High Idle diagnosis?
on your air intake there is two sensor like things they have wires going to them the one on the left side is probly the problem mine got stuck and would idle high. take the intake hose of the engine side ( three torx bolts ) and put your finger over the small hole see if that slows the idle. :D
I had that same problem and my fix was(bare with me here because i don't know the name of the part) on the drivers side just between the manifold and the wheel well there is a small whiteish valve with 3 hoses leading to it, one on the left and the right and one on the bottom, on mine the bottom one was melted shut and when i fixed that, it fixed my idle. hope this helps.
Erik
