I am bleeding my clutch fluid every other day and it is obviously burnt. It works fine right after i change the fluid but within 120kms the pedal has faded to the floor.
I am not sure what the PO replaced the slave cylinder with (OEM or Aftermarket) but had indicated that it was changed.
