comancheboy Posted September 27, 2009 Share Posted September 27, 2009 I got a 88 comanche that needs a better lift. I heard that you can use the front coils out of a zj grand cherokee for a 3inch lift. will it work if i take the upper and lower control arms and trac bar (since mines blown out) and coils and get a 3inch lift for the front? or will it throw the front end out of alignment if i use those parts out of the grand cherokee Link to comment Share on other sites More sharing options...
Pete M Posted September 27, 2009 Share Posted September 27, 2009 V8 grand cherokee coils will give 3" of lift to an TJ, only 1 inch in an MJ. Link to comment Share on other sites More sharing options...
Geonovast Posted September 27, 2009 Share Posted September 27, 2009 Grabbing the control arms off the ZJ wouldn't help you, they're the same as XJ/MJ ones. The difference is where the spring meets the body. Also, ANY height change will affect your toe alignment. Link to comment Share on other sites More sharing options...
