xflowdaboi352 Posted September 23, 2009 Posted September 23, 2009 Is the reverse on and auto trans controlled by the wires that plug in to the side of the trans
jpdocdave Posted September 23, 2009 Posted September 23, 2009 reverse is mechanical on most transmissions. i'm no auto expert, i've had a few apart, i'm gonna say the answer is no. maybe some more info would help.
xflowdaboi352 Posted September 23, 2009 Author Posted September 23, 2009 ok thx man cause i can't firgue it out it virbrate rly bad when u give it gas bit if u let it idle backwards it fine :dunno:
xflowdaboi352 Posted September 23, 2009 Author Posted September 23, 2009 nope brand new like it doesnt go just revs up and vibrate and when u put it in 4wd it way worse
WBKrazy Posted September 23, 2009 Posted September 23, 2009 there is a reverse clutch in the trans, my guess is your trans is on it's way to heaven....
Geonovast Posted September 23, 2009 Posted September 23, 2009 Does it do it with the T-case in neutral?
