glundblad Posted September 20, 2009 Share Posted September 20, 2009 Has anyone ever tried to install electric seats from a Cherokee limited into a comanche? Both would be 1987. Do you think they would fit or would they be too high (similar to the slider cherokee seats)? Do you think it would be fairly easy to run power to them? Link to comment Share on other sites More sharing options...
Pete M Posted September 20, 2009 Share Posted September 20, 2009 It'd be a tight fit for sure and require custom work, but probably possible. Link to comment Share on other sites More sharing options...
glundblad Posted September 21, 2009 Author Share Posted September 21, 2009 It'd be a tight fit for sure and require custom work, but probably possible. If it didnt fit, it appears that the seat frame could be unbolted from the power seat track and bolted to a standard XJ bucket track. It would no longer be a power seat but it would still fit. Wouldnt you agree? Link to comment Share on other sites More sharing options...
Pete M Posted September 21, 2009 Share Posted September 21, 2009 Yes, the seat should be useable, but if you have buckets now, you'll need the sliders from an MJ or XJ to mate the seat to the MJ bench floor brackets. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted September 21, 2009 Share Posted September 21, 2009 The power to these is a hot wire and a ground wire, thats all. Find a battery hot under in the fuse box, run a wire from it and another fuse to the seat, and tie in the ground and youre good to go. Link to comment Share on other sites More sharing options...
