danbyrambler Posted July 7, 2014 Share Posted July 7, 2014 Here ya go: site:comanche club.com power comfort jumper http://comancheclub.com/topic/17232-broken-powercomfort-button/page-2 Always ck out Cruiser 1st :thumbsup: Link to comment Share on other sites More sharing options...
Incommando Posted July 7, 2014 Share Posted July 7, 2014 2 different shifting programs. Power is for us. comfort is for Grandma. Factory defaulted the tCU to Power in 1991. Here's how you fix it once and for all. Bypassing the Power/Comfort Switch Remove and unplug the switch. In the harness are 3 wires One has a stripe, one is tan, and the other black. Make a 4" jumper wire with a male spade at each end. Plug one end in the cavity for the tan wire and the other in the cavity for the striped wire and you'll be in permanent Power mode. Stuff the harness back in and reinstall the switch for looks. Adjust your TV cable while you're at it and feel your Jeep wake up. http://www.cherokeeforum.com/f2/free-quick-fix-41821/ Make sure the 7.5 amp "trans" fuse is not blown also. Yep, that works. Just tried it. Which one did you do? Or both? The adjustment thingy. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 7, 2014 Share Posted July 7, 2014 2 different shifting programs. Power is for us. comfort is for Grandma. Factory defaulted the tCU to Power in 1991. Here's how you fix it once and for all. Bypassing the Power/Comfort Switch Remove and unplug the switch. In the harness are 3 wires One has a stripe, one is tan, and the other black. Make a 4" jumper wire with a male spade at each end. Plug one end in the cavity for the tan wire and the other in the cavity for the striped wire and you'll be in permanent Power mode. Stuff the harness back in and reinstall the switch for looks. Adjust your TV cable while you're at it and feel your Jeep wake up. http://www.cherokeeforum.com/f2/free-quick-fix-41821/ Make sure the 7.5 amp "trans" fuse is not blown also. Yep, that works. Just tried it.Which one did you do? Or both? The adjustment thingy. That's always a good thing to do. Link to comment Share on other sites More sharing options...
