Worn Track Bar
Will a worn track bar make my MJ feel squirrelly at high speed? When traveling at highway speed sometimes when hit small bump on a curve or just driving straight, when hit bump, it feels like the steering is loose. As for history I rebuilt the front a couple of years back (2) and :doh: didn't replace the track bar, and I was wondering if could be the cause of my problem?
It can be the cause, but that doest mean that it is the cause. I would start there first. With the truck sitting on the ground, have a friend turn the steering back and forth and look for movement. Replace anything you see move. Also look at the frame around the steering box for cracks and breaks. good luck!
