bowmans86mj Posted August 12, 2009 Share Posted August 12, 2009 i just recently purchased a 86 mj, 2.5 4 speed. everything seems to be working good. needs new brake lines and front wheel drive doesnt work but seems to be a vacuum line. after a few fender adjustments i squeezed 33x9x15's under. i was just wondering if anyone had any tips and if anyone has been to haspin acres in indiana and if i would be alright down there to have some fun with it??? thanks for the help Link to comment Share on other sites More sharing options...
64 Cheyenne Posted August 13, 2009 Share Posted August 13, 2009 FWIW,I wouldn't take a vehicle anywhere with a questionable brake issue. Got some pics?Any lift? Oh, and welcome to the club! Link to comment Share on other sites More sharing options...
bowmans86mj Posted August 13, 2009 Author Share Posted August 13, 2009 the brakes are this weekend's job.. i will be getting them fixed for sure before that. wouldnt want anyone getting hurt. but ya i will try to get some pics uploaded later on today. and no i do not have any lift. i found a few kits i would like to look into but i think I'm going to run this one till it pukes and then get a different one in a little better shape then actualy spend money to get it lifted thank you for the welcome to the club and thank you for the post. also does anyone know the easiest way to remove the vacuum lines on the front drive shaft and still enable 4x4?? thank you again Link to comment Share on other sites More sharing options...
jaekl Posted August 13, 2009 Share Posted August 13, 2009 There are many here who say use washers to keep the axle engage, and there are many posts. It's also very easy to check to see if it still works. Just run a good vacuum line to it and see if it works. (Taking the vacuum motor off the axle makes it easy to check) If so then trace the vacuum lines and check them here and there. There is vacuum to the selector on the case and it just reroutes the vacuum to engage or diengage. The light is to go on once engaged and then the vacuum is directed to the light switch. Very likely you have a clogged line or a hole. Your choice, but I'm just saying it usually doesn't take much to get it working again. Link to comment Share on other sites More sharing options...
bowmans86mj Posted August 13, 2009 Author Share Posted August 13, 2009 well in that case i will look into just replacing the vacuum lines to get it going... i have a KILLER exhaust leak that will need to be fixed asap also. what kind of lifts would you guys recomend best for price and quality?? Link to comment Share on other sites More sharing options...
86customanche Posted August 13, 2009 Share Posted August 13, 2009 i have a 86 2.5 4 speed as well and had that same vacuum issue. all i did was take off the cover and basically permanently put the fork that moves into 4wd position. all it does is make it so there is no work needed to be done by the vacuum for 4wd to work and it doesnt effect 2wd at all. very easy fix and it costs nothing :clapping: Link to comment Share on other sites More sharing options...
bowmans86mj Posted August 16, 2009 Author Share Posted August 16, 2009 got the exhaust leak fixed and the 4x4 locked in. alls left is the brake's and then were off to haspin Link to comment Share on other sites More sharing options...
