if i but a cherokee 3in lift under the front axle with two inch spacers would i need all need arms and steering arms
So then you would have a net of 5''? Yeah you will need to adjust steering, perfer new set up, at least longer LCA, but suggest adjustable UCA and LCA, an adjustable track bar, adjustments to the brake lines as well. Also either ditch the sway bar or run disconnects.
