JeffK Posted July 21, 2009 Posted July 21, 2009 So we got our first major down pour this afternoon and afterward I checked the status of my baby powder. The passenger side had some from the door seal and of all places the grommet around the antenna cable. The drivers side was nearly all from around the fuse box. The seal between the cowl and hood is history so water is running down the firewall and then apparently between the fuse box and the big connector in the engine compartment. Is there some type of gasket between this connector and the fuse box?
ren Posted July 21, 2009 Posted July 21, 2009 Mine used to have a white "foam" gasket around the part that comes through from the inside. Now, it has a gasket made from a trashed "neoprene" seatcover that I found in the junkyard. I also went ahead and cleaned the connector on both sides, and reapplied some "NoOx" to them. The NoOx I got from a friend who does telecom work. It waterproofs and corrosion proofs at the same time.
JeffK Posted July 21, 2009 Author Posted July 21, 2009 Thanks. Judging from the number my leaking clutch master cylinder did on the fuses and some of the electrical connectors, I'd say that gasket is gone. Is this what you're talking about? NoOx
ren Posted July 21, 2009 Posted July 21, 2009 That's the stuff. My friend gets it in small "tubs" about the size of a potato salad tub. One tub will lasts for several years, for an auto enthusist. I use it for all the electrical connections in my vehicles. I have had no trouble in years, including the fusebox on my 5 speed XJ.
JeffK Posted July 21, 2009 Author Posted July 21, 2009 There's a electrical supply house on my way to the JY. Thanks for the advise. :thumbsup:
Eagle Posted July 22, 2009 Posted July 22, 2009 NoOx is not a replacement for the gasket. NoOx is one of several brands for a mineral oil-based grease or goo that's used on electocal contacts to prevent (TADA!) ... oxidation.
ren Posted July 22, 2009 Posted July 22, 2009 While NoOx is not a replacement for the gasket, I did tell him how I replaced the gasket on my MJ, and how I have prevented corrosion of the contacts in the plug. His game now.
JeffK Posted July 22, 2009 Author Posted July 22, 2009 While NoOx is not a replacement for the gasket, I did tell him how I replaced the gasket on my MJ, and how I have prevented corrosion of the contacts in the plug. His game now. I understood that, even though I may have not worded it as such in my post. My mistake. I've got a big sheet of neoprene type stuff here to make a new gasket out of. I also picked up some NoOx for the electrical connections. Thanks for the help. :thumbsup:
