c clip rear end issue
a few weeks ago my axel came out due to the c clip coming out i put my c clip back in and changed the outer bearing there seems to be to much slack in the axel on passenger side the driver side is tighter i figure the c clip will come back out what could couse all the slack could it be that side gear in the rear end need help
thier is a gap between the center pin and the passenger side axel end its a very visable gap the other side is not as big i think maybe that side gear need a shim or something i can pull on the axel and is moves back in forth alot more than the drivers side cause i jacked that side up to see how much play it had and it only had a little play
...i jacked that side up to see how much play it had and it only had a little play...
Play is measured in thousanths (0.00X), using a dial indicator. "A little" I still too general. Sorry...
Can you take pics of the carrier/spiders?
Rob L.
