thejum57 Posted June 27, 2009 Posted June 27, 2009 I have an 87 Cavalier with the 2.8 MFI. Last October it wouldn't start, and fuel was peeing from it. I couln't afford to fix it untill now. I replaced the fuel pressure regulator, and it starts o.k. The problem is the check engine light glows now. Would that be caused by sitting so long & the battery discharging? :hmm:
jtdesigns Posted June 28, 2009 Posted June 28, 2009 I have an 87 Cavalier with the 2.8 MFI. Last October it wouldn't start, and fuel was peeing from it. I couln't afford to fix it untill now. I replaced the fuel pressure regulator, and it starts o.k. The problem is the check engine light glows now. Would that be caused by sitting so long & the battery discharging? :hmm: Do you know if it sets a code??
