cklanish88mj Posted June 22, 2009 Share Posted June 22, 2009 i have the big fuel gauge cluster in now would like to swap to tach and oil/temp gauges how do i make the mileage match the gauge cluster i want to put in has 130.000 miles mine truck has 108.000 any info appreciated Link to comment Share on other sites More sharing options...
mm's mj Posted June 22, 2009 Share Posted June 22, 2009 Great DIY thread on the cluster swap, including how to reset the odometer. http://www.naxja.org/forum/showthread.php?t=921205 Link to comment Share on other sites More sharing options...
Timmaay Posted June 23, 2009 Share Posted June 23, 2009 Great DIY thread on the cluster swap, including how to reset the odometer. http://www.naxja.org/forum/showthread.php?t=921205 Yep, that's the diy I used. The only thing I had trouble with is when he is talking about using the hobby knife, he never actually says what to remove. Now I know (after warping one speedo) he is referring to the little c clip on the end of the numbers. I found that a good and sharp pair of needle nose pliers works best for the removal of that clip. Link to comment Share on other sites More sharing options...
cklanish88mj Posted June 23, 2009 Author Share Posted June 23, 2009 i have column shift so what do i do there for indicator Link to comment Share on other sites More sharing options...
Geonovast Posted June 23, 2009 Share Posted June 23, 2009 viewtopic.php?f=9&t=14904&p=150303 Link to comment Share on other sites More sharing options...
