rear axle help
well it was not my trans or transfer case but my rear axle came out a bit from the rear end that c clip came out i think i have a 355 rear mine is a 92 4.0 automatic i need to replace the axle from wear what axle can i use from cherokee ect so i can begin looking I'm still changing trans case cause it pops when put in 4 wheel any info will help
Are you asking about replacing just the axle shaft or the entire axle? Any year Cherokee or Wrangler can donate it's entire rear axle. You'll just need to remove the bracketry and weld on the MJ stuff. For the axle shaft itself, I think any Dana 35 from any Jeep post 91 can be a donor.
Here is the shifter setup procedure for the t-case if it helps:
I'm just going to replace the axle from the pasenger side that c clip came out and you can pull the axle out by hand i was a little worn on the end of the axle where it goes into the rear end gears where the c clip holds it i suppose it wore down and thats how the axle worked out so i should probably change it and in stall a new c clip also
