mjeff87 Posted May 26, 2009 Posted May 26, 2009 There's what looks to be an early to mid-80's C20 pickup down at the junkyard behind the fence. Can't get up close to look at it, but hopefully they'll be putting it out in the 'yard in a couple of weeks.....all I can see is that it has 8 lug axles on it (2WD). Any idea what the engine/tranny combo might be in it? What are the odds on it having a 454 (probably 2-bolt mains, but.....still a 454) under the hood? If it does, I think I just found the drivetrain for the Nova build :D Jeff
oldrusty Posted May 26, 2009 Posted May 26, 2009 If I remember correctly the 454 wasnt available in the early to mid 80's gm trucks. I think the biggest engine optoin was a 350..........Doesnt mean someone couldnt have swapped one in there though. I really havent messed with the chevy trucks in a while though so I may be completely wrong.
mjeff87 Posted May 26, 2009 Author Posted May 26, 2009 well, doing a little research, it could have a 250, 305, 350, 454 or a diesel (but it's not a diesel, I know that much). I don't want no stinkin' small block that I'm gonna have to dump gobs of $$$ into in performance parts to get HP. I just want to drop a BB in it and be done :clapping: Jeff
GirsMJ86 Posted May 26, 2009 Posted May 26, 2009 The 454 was not around till '90 in the newer '88 style trucks. The biggest option was the 350 in the '80s C/Ks other then the Detroit Diesels. Unless someone did a swap, don't count on the 454 unless you look in the newer '88+ models... mainly the '90 SS package. ~Alex EDIT: My years were off according to my booklet :doh:
oldrusty Posted May 27, 2009 Posted May 27, 2009 If you really want to get creative you could drop in one of these.... :D :D :D
