thejum57 Posted May 17, 2009 Share Posted May 17, 2009 Does anyone have any advice that will help me remove the manifold from my 86 2.5 four cyl.? The front welch plug nuked, and it looks like I need to get the manifold out of the way to get to it. Probly not a bad idea to replace the rest of them while it's apart. Any advice ,pics will be very helpfull. Are there any bolts under the manifold(s) or just the ones on top? Thanx alot people, you always have great advice & feedback. :cheers: Link to comment Share on other sites More sharing options...
BPB Posted May 18, 2009 Share Posted May 18, 2009 If it is anything like the 4.0 then there will be bolts on the bottom. Some will take a Frankenstein assembly of wibble-wobbles and extensions othere will require 1/8 turn at a time with a wrench. Best advice is to soak everything with PB blaster for a couple days. Link to comment Share on other sites More sharing options...
garmj Posted May 18, 2009 Share Posted May 18, 2009 Just did mine because of a cracked exhaust manifold. There are2 bolts that you have to get from underneath the manifold, all it takes is a 6" extension and a swivel socket and ita a done deal.Exhaust pipe bolts and EGR tube are harder to deal with. Once you get the air cleaner box and PS pump outa the way it aint bad. :cheers: Link to comment Share on other sites More sharing options...
