AX-15 Shifter Cane
*disclaimer- I have not done this, but there was a similar thread on here or NAXJA not too long ago...only going on what I remember.....
It does seperate. Clamp the large round black piece in a bench vise and slide a thin metal something or other up along one of the flat sides of the square stock going into it and pull the bottom piece, which should come off.
Like I said, I've not done this before. HTH,
Jeff
edit: here you go.....http://www.naxja.org/forum/showthread.p ... 15+shifter
it's suggested that hacksaw blades are good for sliding along the flat parts to disengage.....excellent pics of the whole assembly on the very last post.
