Got a 92 cherokee....4.0ho auto... the wipers and cruise control both don't work.... cannot locate a bad fuse anywhere..... any ideas.....
There is a breaker for the wipers on the fuse block under the dash. 5.5 if I remember right. Far as the cruise control, a lot of things effect it and will make it not work. This is out of the troubleshooting section of the FSM:
NO CRUISE CONTROL WHEN SET BUTTON IS PRESSED & RELEASED
Check for: blown fuse, no vacuum at servo and/or defective
servo, disconnected speed control cable, brakelight switch out of
adjustment, faulty electrical circuit, faulty Park/Neutral switch
input to PCM, faulty PCM.
Hope this helps.
:cheers:
