SomeNew Name Posted April 28, 2009 Posted April 28, 2009 Hey Guys, I've reciently come across a push bar from a cherokee but don't have the brackets to mount it to the frame.. so I'm going to fab some up.. but seeing as how I'm quite a distance from the truck and can't get out to do the measurements myself.. I was wondering if anyone knew off hand the dimensions for the brackets, or have a detailed drawing of them.. or has even made then reciently.. and still had the plans.. any assistance would be awesome thanks guys!
Drahcir495 Posted April 28, 2009 Posted April 28, 2009 I would like to see a picture, because mine bolts to the bumper ~ not the frame :popcorn: .
maddzz1 Posted April 28, 2009 Posted April 28, 2009 Mine bolts to both. But their are no seperate brackets with it. I havent put it on yet so I can get you some pics tomorrow of what mine looks like if you want
SomeNew Name Posted April 28, 2009 Author Posted April 28, 2009 well I guess mines a wee bit different then cause it's designed to fit around the stock front bumper, but doesn't meet up with the frame, not even close, which made me think there was seperate brackets used to attach it. If your's is all one peice, than I would love to see those pictures, and just try to fab something up similar to that. Thanks~!
maddzz1 Posted April 28, 2009 Posted April 28, 2009 yeah its one piece, and it has the things that come out toward the sides and protect the headlights too.
maddzz1 Posted April 29, 2009 Posted April 29, 2009 I was wrong; it doent mount to the frame. here's the pics anyway:
SomeNew Name Posted April 29, 2009 Author Posted April 29, 2009 ok I see what's going on here then... mine just had the bolt hole at the bottom, without the tab there.. plus on mine someone drilled another hole so that's how I got the impression that there was a mounting bracket.. to me , it makes sense to have the push bar tied into the frame somehow, and I guess having it tied into the bumper is basically the same thing as tying it into the frame.. but I guess I'm going to have to make something to have it tied into both.. thanks alot for the picture!! answered alot of my questions
maddzz1 Posted April 29, 2009 Posted April 29, 2009 It would be nice if the brackets line up with the frame, then maybe just weld some L channel to the bracket so that they run along the frame rail. Then just drill some holes and bolt it to the frame. If the brackets don't line up with the frame it will be alot more difficult
