All of the other lights work, turn, hazard, brakes, reverse but the tail lights and license plate lights do not work when I turn on the headlights. Which of the 3 lights in the corner lens are supposed to turn on? (top, middle or bottom) I think I will start with the bulbs and go from there.
I also took the bed off to fix the frame and I only put one ground screw back when I replaced the bed on the weekend (behind the driver side lens cover on the bed) could I have missed another ground somewhere?
You can check on the DIY section for the electrical manual, to help you. :smart:
If I my memory is right, the ground behind the driver taillight are used for lights and the fuel pump.
You could check the connector for corrosion. :dunno:
The blue wire is for the night light & the plate light.
There is a connector in the rear wire harness located right behind the drivers side rear tire. Corrosion inside can cause all sorts of headaches. :(
there is no power coming to the blue wire at all, I even tested it up where it comes out of the cab, before I go tearing out my entire cab to trace the wire back can anyone tell me where it connects to the main headlight wire, everything else works just fine back there
I suppose I could always just rig it directly to the headlight switch, but I would still need to know whereabouts I can find where the wire to the rear lights starts
