New guy, 88 comanche 4x4 4.0 5 speed
They blow up. Mine blew a hole out the side of the trans while I was just tooling along with traffic on the freeway. :dunno:
They are barely adequate for a stock 4.0L with street tires.
The renix and a 96 HO do not share a common crankshaft hole for the bearing. Both the inner and outer diameters of the pilot bearings changed.
The CJ bushing will only work with swapping a late model AX-15 onto a renix era 4.0. If you're using an HO 4.0, you just need the AX-15 and the appropriate factory bearing. :thumbsup:
Pump? Yes, it'll still pump fuel.
Fuel level sender? The gauge will read backwards because they switch the polarity in 91. And someone correct me if I'm remembering this wrong, but I think if you swap the positive and neg wires, it still won't be perfectly accurate.
