This is a pic of an 89 XJ I just got
On the 87 MJ I put a screw in this
The small rubber plug that comes out of the TB - carries vacuum to the MAP sensor.On the top seems that it is open
Is it missing a vacuum line? does it need/or is it supposed to be plugged?
If you pull that connector off the TBI, you can see the backside of the top is a plug that holds the connector to the TBI.
