Temp gauge not working
Does anyone knows what can i do to make it work? after the accident small things like this started to show problems, please help me guys :bowdown:
Turn on the ignition key to RUN. Disconnect the wire from the sensor; the gauge needle should go to C. If not, touch the sender wire to ground; the gauge needle should go to H. If okay, replace sender. If not there is an open circuit between the sender and the temp gauge.
