86FUBAR Posted March 28, 2009 Posted March 28, 2009 i herd on here some where that it was possible to use one but couldnt find it , anybody know anything into this ? year ,make, model other info etc...
ren Posted March 28, 2009 Posted March 28, 2009 S-10 slipyokes fit, as should the yokes from the T-350, 700r4 and the 4l60. The T-400 uses a bigger yoke, with more splines on it. Oh, and 2 OR 4wd yokes work. You can also use the front D/S if you need to find a driveshaft in a hurry, but you might need to cut it down, depending on the length needed.
