discs for my '44
It was a good weekend. Got Pat's bumper mounted up finally (see post in the projects forum), and scored a set of ZJ D44 disc backing plates and calipers from the 'yard. $23 out the door.....
I was going to use a set of Crown Vic discs but this makes it sooooo much easier!
Jeff
Image Not Found
yep, late model ZJ D44. Had a funny diff cover, which I may go back and snag......thinking about doubling the stock cover using it and cutting out the fill hole area.
Funny thing is it was a C clip axle, so I had to pull them to get the shafts out. I pocketed the center pin, too (hopefully I'll never need it!)
Jeff
Rotors were shot, and the parking brake pads were shot also. I got all the hardware for the e-brake (springs/pins/levers, etc), just gonna get new rotors and pads.
They didn't charge me for the brake hoses from the caliper that have the banjo fitting and mounting bracket on the other end :D . I was gonna take the brake cables, 'cause they have the ends that snap into the lever, but didn't. I can pick them up new for a few $$, and it looks like I'll be able to booger them into the factory MJ cable bracket thingy under the bed without too much of a problem. If not, I'll use the MJ cables and adapt them.
  • 1 year later...
heh.....no I didn't. They're still sitting in the parts project pile, to go in maybe eventually.
I ran across a smokin' deal on a set of fully rebuilt loaded drum backing plates locally, so I just ended up staying with drums to keep things simple. Plus I swapped in a dual diapraghm XJ booster/MC, which really improved the stock braking system. For now, brakes are working great, but I still might do the discs later on down the road.
Jeff
