wranglercory Posted March 22, 2009 Share Posted March 22, 2009 I was just wondering if anyone has installed a set of these buckets. I just got a pair of buckets from a two door Cherokee and after looking at them I think I will drill out the spot welds on the support in front of the seat that in the Cherokee the front of the seat bolts to. I plan to just drill out the spot welds on the Comanche and weld in the support from the Cherokee. I am just wondering if there is a reason I havent seen a write up on swaping buckets that way . I'm planning on doing a write up unless this has been done. The write up I saw had you completely dissamble the seats and use the bench seat brackets. The way I am thinking it can be done amounts to drilling out spot welds on the support to get the support out of both vehicles swaping the Cherokee support into the Comanche then I havent seen where the rear bolts will need to go but the simplest way I see is to mark and drill out the rear holes and put a grade 8 bolt through with a steel plate to add support to the under side. Link to comment Share on other sites More sharing options...
Darren Posted March 23, 2009 Share Posted March 23, 2009 I was just wondering if anyone has installed a set of these buckets. I just got a pair of buckets from a two door Cherokee and after looking at them I think I will drill out the spot welds on the support in front of the seat that in the Cherokee the front of the seat bolts to. I plan to just drill out the spot welds on the Comanche and weld in the support from the Cherokee. I am just wondering if there is a reason I havent seen a write up on swaping buckets that way . I'm planning on doing a write up unless this has been done. The write up I saw had you completely dissamble the seats and use the bench seat brackets. The way I am thinking it can be done amounts to drilling out spot welds on the support to get the support out of both vehicles swaping the Cherokee support into the Comanche then I havent seen where the rear bolts will need to go but the simplest way I see is to mark and drill out the rear holes and put a grade 8 bolt through with a steel plate to add support to the under side. Try a search, we just covered this in like 4 threads. Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 23, 2009 Share Posted March 23, 2009 I was just wondering if anyone has installed a set of these buckets. I just got a pair of buckets from a two door Cherokee and after looking at them I think I will drill out the spot welds on the support in front of the seat that in the Cherokee the front of the seat bolts to. I plan to just drill out the spot welds on the Comanche and weld in the support from the Cherokee. I am just wondering if there is a reason I havent seen a write up on swaping buckets that way . I'm planning on doing a write up unless this has been done. The write up I saw had you completely dissamble the seats and use the bench seat brackets. The way I am thinking it can be done amounts to drilling out spot welds on the support to get the support out of both vehicles swaping the Cherokee support into the Comanche then I havent seen where the rear bolts will need to go but the simplest way I see is to mark and drill out the rear holes and put a grade 8 bolt through with a steel plate to add support to the under side. Try a search, we just covered this in like 4 threads. Well he is still a little new so perhaps help him out to ensure he knows how to use search, and perhaps give him a link since you know there is like 4 threads on this subject, kinda get my drift man? well under the search link type what you looking for and click search all terms for best results, I cam up with this one that may help out... viewtopic.php?f=2&t=15504&hilit=97+seats+in+MJ Link to comment Share on other sites More sharing options...
wranglercory Posted July 2, 2009 Author Share Posted July 2, 2009 Well I have completed one of the seats and what I did worked flawlessly. I completely removed the bench seat, then I welded in the bucket seat perch. This is the part on Cherokees that the front two seat bolts bolt into. I had went to the JY and used a spot weld bit to remove them. lined everything up and presto the only bolt that remained was the rear inside bolt the other rear I drilled Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 3, 2009 Share Posted July 3, 2009 good deal glad it worked for you. nOw want pics of finished project now you hear? :thumbsup: Link to comment Share on other sites More sharing options...
