kar120c Posted February 19, 2009 Share Posted February 19, 2009 Finally got around to pulling the engine today. Rebuilding the 2.5 and doing a 4wd swap at the same time. Need to take some pics and get a thread started in the projects section. Anyways I can't decide to reuse the timing chain or not. The engine is pretty tired with about 250k on it, but the timing chain/gears were replaced along with the tension thingy about 25k ago (I have the receipt, it was my dads truck). I really don't want to spend $150 on another timing set and would rather put it elsewhere into the rebuild. Keep or replace? I don't see any reason why I couldn't... Link to comment Share on other sites More sharing options...
mjeff87 Posted February 19, 2009 Share Posted February 19, 2009 If the set is only 25K old, I probably wouldn't fuss with it. At the most, I'd pop the cover and inspect the tensioner to see how far it has self-adjusted itself, if any. If more than 1/3 I'd probably put a new one on. My OEM set lasted to about 160K or so, and even then it was just the tensioner that was shot (but I replaced everything since I had it all torn down at that point). Jeff Link to comment Share on other sites More sharing options...
BLHTAZ Posted February 19, 2009 Share Posted February 19, 2009 If the set is only 25K old, I probably wouldn't fuss with it. At the most, I'd pop the cover and inspect the tensioner to see how far it has self-adjusted itself, if any. If more than 1/3 I'd probably put a new one on. My OEM set lasted to about 160K or so, and even then it was just the tensioner that was shot (but I replaced everything since I had it all torn down at that point). Jeff :agree: It's just gettin' broke in... :cheers: Link to comment Share on other sites More sharing options...
kar120c Posted February 19, 2009 Author Share Posted February 19, 2009 Thanks that is what I was thinking. I don't think it had adjusted much if at all. There was no slop in the chain even without it installed. Link to comment Share on other sites More sharing options...
