why not just separate the brackets from the 90 and weld them to the 97. Cuz the only lthread i know of is bench to buckets in the DYI
You can't that was the route I was going to take to install '00 seat from an XJ, the brackets are different.
Pug you either have to get the brackets (welded to floorboard) from the donor or fab some up.
I finaly figured out how to bolt in the new seats. Unbolted both frames on both sets. Then were the factory frames were riveted i bolted a 1/8 flat steel to the new buckets. I then bolted the old frame i took off to the factory mounting . set the new seat on top off old bracket were the flat steel is marked it added more flat steel were i marked . Then drilled 3/8 hole into seat frame and flat steel. Bolted together every thing lined up with factory mounting points. It took about 2 hours first seat and about 45 min other seat. Sorry i don't have any picture
the easiest way to do it is remove the floor bracket off a 95+ xj and tack weld it to the floor, 95 + seats are the same brackets in all xjs 95 and newer and all zjs and wjs etc. Project ONYX is done like this in the build threads.
I tried that but the seat sat to high. I was looking at the sun viser. Also i do not have have a welder.
