SuperWade2 Posted February 7, 2009 Posted February 7, 2009 Will the OEM Draglink and Tie Rod from my 99 TJ D30 bolt right onto the MJ D30? Some of the ends of my MJ steering stuff are pretty wore out and the TJ stuff is just sitting on the shelf in the garage since upgrading to the Currie setup.
james750 Posted February 8, 2009 Posted February 8, 2009 It should, IIRC the TJ/LJ/ZJ/XJ/MJ all have the same steering setup. The thing I would be unsure about would be if the newer draglink will bolt up to the older Pitman arm.
