comanche13 Posted February 2, 2009 Posted February 2, 2009 i took off my stock bumper and I'm looking how it mounted and its just through some skinny metal how do i mount it so it is alot stronger and i can winch with it? any help would be great I'm getting a friend to mount it for me hopfully tomo if i get the info i need pictures would be great also =)
comanche13 Posted February 2, 2009 Author Posted February 2, 2009 here's some pictures of were it mounts
Pete M Posted February 2, 2009 Posted February 2, 2009 With big long mounting brackets like these. You'll want to use as many big grade 8 bolts as you can (sometimes including the steering box bolts like I did)
comanche13 Posted February 2, 2009 Author Posted February 2, 2009 but as you can see in the pictures where are the holes i bolt to or do i need to drill and tap them?
Pete M Posted February 2, 2009 Posted February 2, 2009 Tap? no. Drill? maybe. I used 2 of the steering box holes and one empty through-hole on the drivers side. On the passengers side I used 2 existing holes and drilled one. There are kits out there that will do pretty much the same job. The company name escapes me at the moment.
reson46 Posted February 3, 2009 Posted February 3, 2009 This is what I did on the driver side. - The front two bolts are 1/2" grade 8. They go through the same holes as the front bolts of the stock bumper bracket. Get rid of those psuedo captured nut things and use regular nuts on the back side. - The next bolt is metric. It is the rear bolt from the stock bumper bracket. This attaches to a nut welded to the inside of the unirail. - The next three are the steering box bolts. This accomplishes the same thing as a C-Rok or TNT steering box brace by spreading out the forces over a much larger area. - The last bolt is grade 8 through an existing hole in the unirail. I think it is 5/8" - basically as big as I could fit through that hole. Here is the passenger side. Besides the steering box bolts, it uses the same holes as the driver side. If you plan on using the bumper for recovery or a winch you need to at least use the three stock bumper bracket bolts, run the bracket along the unirail, and use the large bolt through the rear at minimum. I also tied the brackets into the sway bar mounts on both sides. Willy
Pete M Posted February 3, 2009 Posted February 3, 2009 Now there is a good idea. :thumbsup: Maybe if they all don't snap off on my next big project truck I can do something similar.
comanche13 Posted February 3, 2009 Author Posted February 3, 2009 are the braces that brace my fender alright to take off? cause otherwise there in the way with the steering bolts
reson46 Posted February 3, 2009 Posted February 3, 2009 are the braces that brace my fender alright to take off? cause otherwise there in the way with the steering bolts I completely removed them. Willy
comanche13 Posted February 3, 2009 Author Posted February 3, 2009 so it doesent make the side fenders all wobly
reson46 Posted February 3, 2009 Posted February 3, 2009 so it doesent make the side fenders all wobly No, as you can see here there is plenty of other stuff holding the fender on. Willy
